why don't i see any shares?!?!?
Hi i mining with MAC i7 bfmining,
but my prohashing dashboard shows my workers but don't show any blocks or hashrate.
What am i doing wrong?
any help please?
Pool 2: prohashing.com Diff:512 +Strtm LU:[14:08:05] User:******
Block: ...6ebf3291729017f0 Diff:78 (563.0M) Started: [14:06:16] I:?
ST:4 F:0 NB:51 AS:0 BW:[ 24/ 0 B/s] E:0.00 BS:7
1 | 13.76/14.30/12.61Mh/s | A:0 R:0+0(none) HW:0/none
Pool: stratum+tcp://prohashing.com:3333 Goal: default
Queued work requests: 2
Share submissions: 0
Accepted shares: 0
Rejected shares: 0 + 0 stale (nan%)
Accepted difficulty shares: 0
Rejected difficulty shares: 0
Network transfer: 1.3 / 0.4 kB ( 0.0 / 0.0 B/s)
Efficiency (accepted * difficulty / 2 KB): 0.00
Items worked on: 0
Stale submissions discarded due to new blocks: 0
Unable to get work from server occasions: 0
Submitting work remotely delay occasions: 0
"pools" : [
"url" : "stratum+tcp://prohashing.com:3333",
"user" : "*****",
"pass" : "n=worker_2",
"pool-priority" : "2"
"user" : "*****",
"pass" : "d=2048",
"pool-priority" : "1"
"user" : "*****",
"pass" : "n=worker_21 d=512",
"pool-priority" : "0"
"api-mcast-port" : "4028",
"api-port" : "4028",
"expiry" : "120",
"expiry-lp" : "3600",
"failover-only" : true,
"failover-switch-delay" : "300",
"gpu-platform" : "0",
"log" : "20",
"no-pool-disable" : true,
"no-client-reconnect" : true,
"no-show-processors" : false,
"no-show-procs" : false,
"queue" : "2",
"quiet-work-updates" : true,
"quiet-work-update" : true,
"scan-time" : "1",
"skip-security-checks" : "0",
"submit-stale" : true,
"temp-hysteresis" : "3",
"shares" : 0,
"kernel-path" : "/Applications/MacMiner.app/Contents/Resources/bfgminer/share/bfgminer"
any help please?
Accepted shares: 0
Items worked on: 0
"pools" : [
"user" : "*****",
"user" : "*****",
"pass" : "d=2048",
"user" : "*****",
"expiry" : "120",
"log" : "20",
"queue" : "2",
"scan-time" : "1",
"shares" : 0,
Re: why don't i see any shares?!?!?
From looking at this report, I don't see anything obviously wrong that stands out.
I'll pass this on to Chris. He'll look at the database and get back to you within a few hours.
Thanks,
-Steve
Thanks,
-Steve
pdavim wrote:Hi i mining with MAC i7 bfmining,
any help please?
Accepted shares: 0
Items worked on: 0
"pools" : [
"user" : "*****",
"user" : "*****",
"pass" : "d=2048",
"user" : "*****",
"expiry" : "120",
"log" : "20",
"queue" : "2",
"scan-time" : "1",
"shares" : 0,
- Chris Sokolowski
- Site Admin
Hi. Could you provide me more information about your hardware? Are you mining on the CPU or do you have dedicated mining hardware attached to the mac?
Hi. I m mining CPU
2,2 Ghz I7 16Gbram
bfgminer version 5.4.2-unknown - Started: [2016-11-07 07:42:17] - [ 0 days 06:00:39]
[M]anage devices [P]ool management [S]ettings [D]isplay options [H]elp [Q]uit
Pool 2: prohashing.com Diff:512 +Strtm LU:[13:42:21] User:*****
Block: ...291a440200da8635 Diff:1.8k (12.90G) Started: [13:41:06] I:?
ST:4 F:1 NB:818 AS:0 BW:[ 52/ 2 B/s] E:0.00 BS:59
1 | 28.13/26.32/27.00Mh/s | A:0 R:0+0(none) HW:0/none
OCL 0: | 28.15/26.38/27.05Mh/s | A:0 R:0+0(none) HW:0/none
[2016-11-07 13:36:44] Stratum from pool 2 detected new block
[2016-11-07 13:37:47] Pool 2 is issuing work for an old block: bfefc6c5cb7197c4
19dd050abf31ca36a19d696f33ac475fe7f6ab5c66981100
[2016-11-07 13:37:47] Network difficulty changed to 1.6k (11.45G)
[2016-11-07 13:37:47] Stratum from pool 2 detected new block
[2016-11-07 13:37:53] Network difficulty changed to 1.64k (11.78G)
[2016-11-07 13:37:53] Stratum from pool 2 detected new block
[2016-11-07 13:39:58] Network difficulty changed to 2.94k (21.03G)
[2016-11-07 13:39:58] Stratum from pool 2 detected new block
[2016-11-07 13:40:57] Network difficulty changed to 1.74k (12.48G)
[2016-11-07 13:40:57] Stratum from pool 2 detected new block
[2016-11-07 13:41:06] Network difficulty changed to 1.8k (12.90G)
[2016-11-07 13:41:06] Stratum from pool 2 detected new block
[2016-11-07 13:41:27] Pool 2 is issuing work for an old block: 8cb2e2042fac4d4f
4e96a6fc047737e133ac596bd931ecf811ed4c39d678b5dd
2,2 Ghz I7 16Gbram
- Chris Sokolowski
- Site Admin
Your hashrate is on the order if 10s of MH/s. If you are mining scrypt with a CPU, you would expect a few kH/s. I think you are mining SHA-256 on that CPU, and we are not a SHA-256 pool. That said, neither scrypt or SHA-256 will be profitable on a CPU. You should instead look to other algorithms that can only be mined on CPUs if you want to make money. I'm not that familiar with what is out there though, so you'll have to do some research.
