Pool reconnects?
Pool reconnects?
Hi;
I've been noticing over the past few days that some of my miners are suffering a reconnect every 15 minutes or so using the proxy.prohashing.com:443 settings. Is something up?
Re: Pool reconnects?
Just as a follow up, it doesn't happen when using prohashing.com:3333.
Thanks for the report. I added a bug report into the system, and Chris will investigate this tomorrow!CptPajamas wrote:Hi;
Happy to help!
- Chris Sokolowski
- Site Admin
I restarted the proxy forwarding server. Did that solve the issue?
I moved all of my miners over to the 3333. I'll test 443 again later and let you know. Thanks for being on top of it!
We haven't heard anything about this issue, so if nobody responds by tomorrow, we will close it as "fixed."
If the issue recurs, please report it again and we'll look at it in more depth.
