X11
kam8882729
X11
Post by kam8882729 » Wed Aug 17, 2016 4:37 pm
Any plans for X11?
Site Admin
Re: X11
Post by Chris Sokolowski » Wed Aug 17, 2016 10:58 pm
We are looking into incorporating other algorithms at some point in the future, but that's a long-term goal. Our mining server is running at high CPU load with the current number of miners, so our first priority is to optimize it to handle more scrypt miners before we can work on other features.
We have some progress on the mining server toward additional algorithms. However, we will need to completely redesign the website to support statistics per-algorithm, which means rewriting the code for every chart on the site. This is our largest challenge and this alone will requires weeks of work. Then, there's also the additional servers we need to buy to host the coins and all the setup required for that.
Multiple algorithms is a major project, but we do want to implement it. That said, based upon our current progress there's no way I could give any timeframe for when we might have it done.
kam8882729
Re: X11
Post by kam8882729 » Thu Aug 18, 2016 7:27 am
OK, thanks for the answer. I'll check back in a few months. I have roughly 4000 MH/s X11 mining on another pool. Would like to try yours out in the future.
