US miners, have you changed over your pool URL yet?
A forum to discuss mining pools, features, etc.
This forum is a place to discuss mining pools, features, etc. Topics can include but are not limited to PROHASHING pool.
Contact:
Post by Sarah Manter » Tue Oct 25, 2022 2:22 pm
If you're a US miner, don't forget, you can switch your pool URL over from prohashing.com to us.mining.prohashing.com, and once you set it, you can forget it.
For example, if you're mining ETHW using Gminer, you would change your config file from
miner.exe --algo ethash --server prohashing.com:3339 --user ProhashingUsername --pass n=workerName,
pause
to
miner.exe --algo ethash --server us.mining.prohashing.com:3339 --user ProhashingUsername --pass n=workerName
pause
