Do you have your backup codes?
Contact:
Post by Sarah Manter » Tue Oct 18, 2022 9:41 am
Do you have backup codes set up for your PROHASHING account's 2fa? If you don't, you may want to disable and reenable 2fa with an authenticator that allows backup codes, such as Authy. 2fa is there to protect you. If you lose your codes, you lose access to your account!
