Callisto Block Reward
A forum to discuss mining pools, features, etc.
This forum is a place to discuss mining pools, features, etc. Topics can include but are not limited to PROHASHING pool.
Marduke
Post by Marduke » Tue Mar 29, 2022 10:41 pm
Question:
Why is the block reward for Callisto here at Prohashing.com only 22.74 CLO for the miners?
The current reward for the miners is 38.88.
The current CLO block reward is 77,76 CLO, which is then spread:
50% or 38.88 CLO to the miners.
40% or 31.10 CLO to Cold Stakers.
10% or 7.77 CLO to the Treasury fund.
Does Prohashing.com take a cut of 16.14 CLO for every CLO block a miner finds?
Re: Callisto Block Reward
Post by Steve Sokolowski » Wed Mar 30, 2022 6:51 am
Marduke wrote: Tue Mar 29, 2022 10:41 pm Question:
There's probably an error in the database. Steven will investigate the problem this afternoon. I have an idea of where the problem might be, so unless someone has posted otherwise, you can assume the problem was resolved if you're reading this on March 31 or after.
Steven Godshall
Post by Steven Godshall » Wed Mar 30, 2022 2:36 pm
It appears CLO's block reward was reduced around 3 months ago, which our system is correctly using. Our system uses the block reward * mining% as specified from this document. Perhaps some other websites haven't updated the value yet? https://github.com/EthereumCommonwealth ... /issues/56
Marduke
Post by Marduke » Thu Mar 31, 2022 7:04 am
Thank you kindly for the explanation.
I did find a detailed spreadsheet of the block reductions and dates.
Back in January, the block reward was reduced to 22.74 CLO.
