No ETH Payouts for 2 days
Hi Guys
Been running ETH payouts daily to Coinbase for a few weeks with no issues, but payouts for 12th and 13th have just stacked up.
can you check any issues please
Re: No ETH Payouts for 2 days
its now paid out, thanks
HI,
Did this stay fixed for you? I am having the same problem with automatic payout to Coinbase - no payouts (eth -> CRO) for almost 5 days.
Thanks!
Thanks!
There are some customers who Coinbase is delaying payouts to for "security reasons." For those customers, we are required to wait 72 hours, but the payouts eventually are processed by Coinbase.
We don't know why these particular customers are affected; it is probably caused by internal Coinbase security procedures. If you are affected, you'll still be paid, just after the 72-hour delay. Chris has also submitted a support ticket to Coinbase, but he has yet to hear back from them, and will let you know when they reply.
Re: No ETH Payouts for 5 days
Thanks so much for your reply, Steve. I noticed Coinbase did a maintenance last night, too - that probably didn't help. Guess we'll hang in there and see what happens.
Also double check your coinbase payouts are activated on prohashing payout page. With the maintenance all my coinbase payouts were turned off and had to be re-enabled.
Thanks for the tip. My payouts are still activated, so the problem lies elsewhere...
Re: No ETH Payouts for 6 days
Forgot to mention, payouts have been normal (daily) for months. Last payout (eth -> CRO) to Coinbase was March 14. Thanks in advance for any feedback or help.
Update: just got payout of entire balance, thanks.
Re: No ETH Payouts for 7 days
Looks like this is happening again. Last payout (eth -> CRO) to Coinbase was August 19.
