Not able to connect with Gminer and ethash-lowmemory
Swampcritter
Post by Swampcritter » Sat Feb 12, 2022 9:44 pm
I've opened a support ticket on this, but wanted to post it here as well in case others are seeing the same:
|                          GMiner v2.78                          |
Algorithm:          Ethash
DevFee:             1 %
Server:
  host:             prohashing.com:3358
  user:             [redacted]
  password:         l=4,i=e3_180,a=ethash-lowmemory,n=[redacted]
Power calculator:   on
Color output:       on
Watchdog:           on
API:                off
Log to file:        off
Selected devices:   GPU0
Intensity:          100
Temperature limits: 90/120
21:39:03 Nvidia Driver: 511.65
21:39:04 Connected to prohashing.com:3358 [50.220.121.209]
21:39:04 Authorized on Stratum Server
21:39:04 Connection Error: Connection closed
21:39:14 Connected to prohashing.com:3358 [50.220.121.209]
21:39:14 Authorized on Stratum Server
21:39:14 Connection Error: Connection closed
-MaVerick-
Re: Not able to connect with Gminer and ethash-lowmemory
Post by -MaVerick- » Sun Feb 13, 2022 7:02 am
Since 2.78 is pretty new, did you try an older version of Gminer? There were some connection issues since 2.76 when looking at the github page.
Swampcritter
Post by Swampcritter » Sun Feb 13, 2022 10:22 am
Tried it with GMiner v2.73 and was getting the same result, so that's why I upgraded to the latest version.
Paula Godshall
Post by Paula Godshall » Fri Feb 18, 2022 7:24 pm
It looks like you're not the only one with this issue (see: viewtopic.php?f=16&t=8675&p=32154)
We are currently investigating.
