ZCash - multiple rounds "Pending"
- OneOfThePetes
Is ZCash PPLNS Stuck?
The previous 2 rounds have been "Pending" for quite a while!
I left because I hate the colour scheme.
Plenty of other mining pools out there that don't look as terrible.
- OneOfThePetes
Re: ZCash - multiple rounds "Pending"
Still "pending".
Is this normal?
Is this normal?
- OneOfThePetes
No change, still "Pending".
I've submitted two support tickets on this issue as well and have not yet received a reply. It has been a few days now and nothing but silence from Prohashing thus far.
- OneOfThePetes
I was about to submit one myself!
It's been over a week of multiple "pending" rounds.
- OneOfThePetes
Did you get a reply yet?
I got the below on 1/13/2022 at about 1:30 PM EST:
"Hello, Thanks for contacting us. We are investigating and will let you know as soon as there is an update. -Prohashing Support"
- OneOfThePetes
Ah good, that's awesome.
We have to remember that the staff would have needed to take a break over the holiday season, and will likely have a lot to catch up on.
It turns out that there may have been a ZCash upgrade that occurred on January 6, which caused blocks since then to be lost. If that's the case, we'll temporarily disable ZCash mining until we can get KAWPOW released this weekend and then fix the ZCash problem.
Steven will update everyone when he finds out if that is the case. Until then, you can continue mining as normal.
- OneOfThePetes
I think I might cry!Steve Sokolowski wrote: ↑Fri Jan 14, 2022 3:59 pm It turns out that there may have been a ZCash upgrade that occurred on January 6, which caused blocks since then to be lost. If that's the case, we'll temporarily disable ZCash mining until we can get KAWPOW released this weekend and then fix the ZCash problem.
