Past year power usage query
Is it possible for me to get a query run and send me either the amount of power my account used in the last year or the total dollar amount I reported? I can do a conversion either way. The only alternative I can see is going though each day of last year in the customer charts and add them up individually. I appreciate it!
- Steven Godshall
Re: Past year power usage query
On the balances page, you can export the daily earnings & power usage data into a CSV file and then sum up the values from 2021.
That works! Thank you.
