Hello Guys,
SOLVED - I accidentally turned on a API key
I have quite problem, on all of my miners start appear read error: "end of file" . Everything was working great on all of my PC´s until restart.
I also try upgrade XMRig to the newest version but without any change. thank´s a lot !!!
config :
"api": {
"id": null,
"worker-id": null
"http": {
"enabled": false,
"host": "127.0.0.1",
"port": 0,
"access-token": null,
"restricted": true
"autosave": true,
"background": false,
"colors": true,
"title": true,
"randomx": {
"init": -1,
"init-avx2": -1,
"mode": "auto",
"1gb-pages": false,
"rdmsr": true,
"wrmsr": true,
"cache_qos": false,
"numa": true,
"scratchpad_prefetch_mode": 1
"cpu": {
"enabled": true,
"huge-pages": true,
"huge-pages-jit": false,
"hw-aes": null,
"priority": null,
"memory-pool": false,
"yield": true,
"asm": true,
"argon2-impl": null,
"astrobwt-max-size": 550,
"astrobwt-avx2": false,
"argon2": [0, 1, 2, 3],
"astrobwt": [0, 1, 2, 3],
"cn": [
[1, 0],
[1, 1],
[1, 2]
"cn-heavy": [
[1, 0],
[1, 1]
"cn-lite": [
[1, 0],
[1, 1],
[1, 2],
[1, 3]
"cn-pico": [
[2, 0],
[2, 1],
[2, 2],
[2, 3]
"cn/upx2": [
[2, 0],
[2, 1],
[2, 2],
[2, 3]
"ghostrider": [
[8, 0],
[8, 1],
[8, 2]
"rx": [0, 1, 2],
"rx/wow": [0, 1, 2, 3],
"cn-lite/0": false,
"cn/0": false,
"rx/arq": "rx/wow",
"rx/keva": "rx/wow"
"opencl": {
"enabled": false,
"cache": true,
"loader": null,
"platform": "AMD",
"adl": true,
"cn-lite/0": false,
"cn/0": false
"cuda": {
"enabled": false,
"loader": null,
"nvml": true,
"cn-lite/0": false,
"cn/0": false
"log-file": null,
"donate-level": 1,
"donate-over-proxy": 1,
"pools": [
"algo": "rx/0",
"coin": "XMR",
"url": "prohashing.com:3359",
"user": "adabob",
"pass": "a=randomx,c=monero,n=PC5",
"rig-id": null,
"nicehash": false,
"keepalive": false,
"enabled": true,
"tls": false,
"tls-fingerprint": null,
"daemon": false,
"socks5": null,
"self-select": null,
"submit-to-origin": false
"retries": 5,
"retry-pause": 5,
"print-time": 60,
"health-print-time": 60,
"dmi": true,
"syslog": false,
"tls": {
"enabled": false,
"protocols": null,
"cert": null,
"cert_key": null,
"ciphers": null,
"ciphersuites": null,
"dhparam": null
"dns": {
"ipv6": false,
"ttl": 30
"user-agent": null,
"verbose": 0,
"watch": true,
"pause-on-battery": false,
"pause-on-active": false
Re: read error: "end of file"
I would save your config as a backup and try to start it with a fresh file. If it works then it was something in your configuration so you can add settings back one by one to see what the problem was.
