So I want some BNB, so i started mining with Prohashing and I reached the minimum threshold, so i kept the address of metamask BNB(bsc). So can I use BSC address for BNB? and why is there a caution symbol beside the logo of BNB in the dashboard?
Thanks
Hi, I am new to prohashing i want some help :)
Re: Hi, I am new to prohashing i want some help :)
i don't think you can use BSC address. it is BEP2 network.
"payouts for this coin are on the mainnet Binance Chain network (BEP-2 style addresses). We do not support payouts or addresses for the Binance Smart Chain (BSC) network. Some exchanges and wallet providers require a destination tag / memo for this coin. Please check if your wallet requires one."
if you want BSC network, there is a way, send the mined BNB (BEP2) to Trust Wallet. Trust Wallet can do a 1-1 exchange of BNB from BEP2 to BSC without incurring any network fee. then you send from Trust Wallet the BNB (BSC) to your metamask wallet. that will incur some small amount of network fee
pmzone wrote: ↑Sun Nov 14, 2021 5:12 ami don't think you can use BSC address. it is BEP2 network.
Hey thanks for telling that I cannot use BSC wallet address, I was about to lose like almost 14$ of BNB I change the wallet address to BEP2
Thanks
if you want to mine BNB (BSC) or commonly known as BEP20, you can go unmineable. it has an option to choose either payout in BEP2 or BEP20 (BSC). the threshold to reach is fairly easy, just need 0.01 BNB while in prohashing to qualify for free payout you need USD75 equivalent which is about 0.12 BNB presently
