Macky82
Post
by Macky82 » Sun Nov 07, 2021 8:31 pm
i have been mining solo for 2 days and not getting any coins on zcash
i have sent support ticket
Alynn
Post
by Alynn » Sun Nov 07, 2021 8:37 pm
Mining solo you only will get coins if you find a block. You will see blocks you have found on the Found Blocks page of the mining tab.
quick edit. Also if the algo you are mining on allows for merge mining you will get FPPS value from the merge mined coins in your chosen coin.
