5 chip gridseed
5 chip gridseed
hello!
I have a gridseed I can't seem to get working with prohashing. Or maybe it is?
I'm using ./minerd --gc3355-detect -o stratum+tcp://prohashing.com:3333 -u myusername -p x --freq=838
and It shows shares happening:
[2016-05-09 23:35:59] Starting Stratum on stratum+tcp://prohashing.com:3333
[2016-05-09 23:35:59] 0: GC3355 chip mining thread started, in SINGLE mode
[2016-05-09 23:35:59] 0: Open device /dev/ttyACM0
[2016-05-09 23:35:59] New Job_id: 1d3fe1 Diff: 4096 Work_id: 02bf5f5a
[2016-05-09 23:36:00] 0: Firmware version: 0x13011401
[2016-05-09 23:36:00] 0: GC3355 5-chip USB-Mini Miner detected
[2016-05-09 23:36:00] 0: Set GC3355 core frequency to 838Mhz
[2016-05-09 23:36:04] Stratum detected new block
[2016-05-09 23:36:04] New Job_id: 1d4028 Diff: 4096 Work_id: 02c498a1
[2016-05-09 23:36:07] Stratum detected new block
[2016-05-09 23:36:07] New Job_id: 1d411e Diff: 4096 Work_id: 02c7f055
[2016-05-09 23:36:09] Stratum detected new block
[2016-05-09 23:36:09] New Job_id: 1d4212 Diff: 4096 Work_id: 02c994ff
[2016-05-09 23:36:10] Stratum detected new block
[2016-05-09 23:36:10] New Job_id: 1d4307 Diff: 4096 Work_id: 02caec50
[2016-05-09 23:36:12] Stratum detected new block
[2016-05-09 23:36:12] New Job_id: 1d43fe Diff: 4096 Work_id: 02ccbdcb
[2016-05-09 23:36:12] New Job_id: 1d44f2 Diff: 4096 Work_id: 02cc087a
[2016-05-09 23:36:15] Stratum detected new block
[2016-05-09 23:36:15] New Job_id: 1d45e9 Diff: 4096 Work_id: 02cf77f4
Is this what I should expect? I don't see hashing being reported from the website side. It shows my test box cpu with 30 KH/s but the gridseed reports zero. Any clue?
I tried bfg and cgminer also. seems the same.
Re: 5 chip gridseed
Also:
GSD 0: 6D8A418A5157 | 838 MHz | 1009.2/70.9 KH/s | A: 1 R: 0 H: 0
Re: 5 chip gridseed
2016-05-09 23:48:59] 0: Set GC3355 core frequency to 838Mhz
[2016-05-09 23:49:17] Accepted cce0a11f GSD 0@4
[2016-05-09 23:49:19] Accepted 3349445b GSD 0@1
[2016-05-09 23:49:32] Accepted 33573b70 GSD 0@1
[2016-05-09 23:49:52] New Job_id: 1ddd13 Diff: 512 Work_id: 05ca0f9d
[2016-05-09 23:49:57] Accepted cd0b6af0 GSD 0@4
looks like it's working now after I changed the d=512.
Re: 5 chip gridseed
nevermind. I'm guessing I didn't wait log enough for dynamic to work after reading the docs.
- Chris Sokolowski
- Site Admin
Re: 5 chip gridseed
Hi. I am not quite sure if you still have a problem - do you still need assistance?
For your information, reported hashrates will be inaccurate or even zero if you're not submitting shares very frequently, like if the difficulty is very high. The automatic difficulty should reduce your difficulty after a few minutes of seeing very few shares, but you will need to be patient. Or you can just use the static difficulty if you want. Be aware that while you cannot set a static difficulty lower than 512, the automatic difficulty can go as low as 32 if necessary.
Re: 5 chip gridseed
hi my name is mary exum i'm new here, and i need help my gridseed 5 chip. it keep missing block and my diff keep going low and high please help
