API to change payout settings
bachel
Post by bachel » Fri Sep 17, 2021 9:50 am
Is it somehow possible to change the payout % for each coin and the payout address (whitelisted) via API ?
The reason I am asking I have hosted miners that I want to bring over to prohashing because I just like the pool and the multiple payout options right now I only mine eth with them payout to binance and exchange to usdc until the hosting fee is covered then I mine to my wallet and I have that controlled with a simple PHP Script and selenium pool side.
It would be amazing to have that implemented hear.
But maybe I am also the only one that is that leazy 🤣
michaelsteward
Re: API to change payout settings
Post by michaelsteward » Fri Sep 17, 2021 11:30 am
Hi bachel,
Currently, our API is read-only so there is no way to change payout information using the API. To allow the API write access to the system a new security framework would need to be implemented. I have created a new feature request ticket in our development task management system. Currently, this ticket is a low priority, but if there is increased interest in this feature I will adjust its priority.
I will keep you updated about the ticket here.
Thanks,
Michael Steward
bachel
Post by bachel » Fri Sep 17, 2021 12:31 pm
michaelsteward wrote: Fri Sep 17, 2021 11:30 am Hi bachel,
Thanks,
Michael Steward
Thanks allot
bachel
Post by bachel » Tue Sep 21, 2021 9:46 am
Seems nobody is in to that idea 🤣
