Getting several Emerald blocks equal to Zero
leomedina01
Post by leomedina01 » Sat Apr 16, 2016 3:04 am
I can see at this moment in my account, that I'm getting several Emerald blocks with value equal to $ 0.0000. In fact all of Emerald blocks today are like this...Is this normal?
Usr> leomedina01
Thanks
Site Admin
Re: Getting several Emerald blocks equal to Zero
Post by Chris Sokolowski » Sat Apr 16, 2016 4:45 am
These blocks are just worth less than $0.00005, and we round to four decimals.
I'll see if we can make a adjustment to show something other than $0. I don't want to add more decimals since I think it would clutter the table.
leomedina01
Post by leomedina01 » Sat Apr 16, 2016 11:35 am
You may display 5E-05 then (what means 5x10^-5), but there's something I didn't get: if block amount is 2.50000000 Emerald, and best sell price is $0.00018125, it should result in $0.000453125, but you said this is worth less than $0.00005...
I'm confused here now... Pls clarify.
Thanks.
