Greetings,
Guys I am very new at this. I have a ethos rig. Can I use it in your pool?
If so I am attaching some info. Please let me know if you can tell what im doing wrong or let me know what other info you guys need.
06:49 AM ethos@82676c 10.0.1.54 /home/ethos # show miner
tailing /var/run/miner.output (use ctrl+c to exit)
^C06:49 AM ethos@82676c 10.0.1.54 /home/ethos # show proxy
tailing /var/run/proxy.output (use ctrl+c to exit)
^C06:49 AM ethos@82676c 10.0.1.54 /home/ethos # show config
Available commands (example: show miner, show proxy, etc):
miner: /var/run/miner.output
proxy: /var/run/proxy.output
ethos-overclock: /var/log/ethos-overclock.log
ethos-update: /var/log/ethos-update.log
ethos-log: /var/run/ethos-log.file
ethos-config: /var/log/ethos-config.log
ethos-overheat-daemon: /var/log/upstart/ethos-overheat-daemon.log
kern: /var/log/kern.log
syslog: /var/log/syslog
06:49 AM ethos@82676c 10.0.1.54 /home/ethos # show ethos-config
tailing /var/log/ethos-config.log (use ctrl+c to exit)
Wed Apr 13 05:41:01 UTC 2016 REMOTE CONFIG SERVER DEFINED, CHECKING URL FORMAT ...
Wed Apr 13 05:41:01 UTC 2016 REMOTE CONFIG URL FORMAT IS NOT OK, RETRIEVING DATA FROM LOCALLY DEFINED CONFIG in /home/ethos/local.conf ...
Wed Apr 13 05:59:04 UTC 2016 REMOTE CONFIG SERVER DEFINED, CHECKING URL FORMAT ...
Wed Apr 13 05:59:04 UTC 2016 REMOTE CONFIG URL FORMAT IS NOT OK, RETRIEVING DATA FROM LOCALLY DEFINED CONFIG in /home/ethos/local.conf ...
Wed Apr 13 05:59:21 UTC 2016 REMOTE CONFIG SERVER DEFINED, CHECKING URL FORMAT ...
Wed Apr 13 05:59:21 UTC 2016 REMOTE CONFIG URL FORMAT IS NOT OK, RETRIEVING DATA FROM LOCALLY DEFINED CONFIG in /home/ethos/local.conf ...
Wed Apr 13 06:00:06 UTC 2016 REMOTE CONFIG SERVER DEFINED, CHECKING URL FORMAT ...
Wed Apr 13 06:00:06 UTC 2016 REMOTE CONFIG URL FORMAT IS NOT OK, RETRIEVING DATA FROM LOCALLY DEFINED CONFIG in /home/ethos/local.conf ...
Wed Apr 13 06:22:03 UTC 2016 REMOTE CONFIG SERVER DEFINED, CHECKING URL FORMAT ...
Wed Apr 13 06:22:03 UTC 2016 REMOTE CONFIG URL FORMAT IS NOT OK, RETRIEVING DATA FROM LOCALLY DEFINED CONFIG in /home/ethos/local.conf ...
Wed Apr 13 06:22:37 UTC 2016 REMOTE CONFIG SERVER DEFINED, CHECKING URL FORMAT ...
Wed Apr 13 06:22:37 UTC 2016 REMOTE CONFIG URL FORMAT IS NOT OK, RETRIEVING DATA FROM LOCALLY DEFINED CONFIG in /home/ethos/local.conf ...
Wed Apr 13 06:26:58 UTC 2016 REMOTE CONFIG SERVER DEFINED, CHECKING URL FORMAT ...
Wed Apr 13 06:26:58 UTC 2016 REMOTE CONFIG URL FORMAT IS NOT OK, RETRIEVING DATA FROM LOCALLY DEFINED CONFIG in /home/ethos/local.conf ...
Wed Apr 13 06:27:19 UTC 2016 REMOTE CONFIG SERVER DEFINED, CHECKING URL FORMAT ...
Wed Apr 13 06:27:19 UTC 2016 REMOTE CONFIG URL FORMAT IS NOT OK, RETRIEVING DATA FROM LOCALLY DEFINED CONFIG in /home/ethos/local.conf ...
Wed Apr 13 06:30:04 UTC 2016 REMOTE CONFIG SERVER DEFINED, CHECKING URL FORMAT ...
Wed Apr 13 06:30:04 UTC 2016 REMOTE CONFIG URL FORMAT IS NOT OK, RETRIEVING DATA FROM LOCALLY DEFINED CONFIG in /home/ethos/local.conf ...
Wed Apr 13 06:40:03 UTC 2016 REMOTE CONFIG SERVER DEFINED, CHECKING URL FORMAT ...
Wed Apr 13 06:40:03 UTC 2016 REMOTE CONFIG URL FORMAT IS NOT OK, RETRIEVING DATA FROM LOCALLY DEFINED CONFIG in /home/ethos/local.conf ...
Wed Apr 13 06:50:04 UTC 2016 REMOTE CONFIG SERVER DEFINED, CHECKING URL FORMAT ...
Wed Apr 13 06:50:04 UTC 2016 REMOTE CONFIG URL FORMAT IS NOT OK, RETRIEVING DATA FROM LOCALLY DEFINED CONFIG in /home/ethos/local.conf ...
^C06:50 AM ethos@82676c 10.0.1.54 /home/ethos # ls
custom.sh Desktop eth-proxy.pid local.conf Pictures remote.conf
06:50 AM ethos@82676c 10.0.1.54 /home/ethos # cat remote.conf
"url": "prohashing.com:3333",
"user": "HashPow3r"
New user help
- Chris Sokolowski
- Site Admin
Re: New user help
Thanks for visiting us. You are trying to mine Ethereum with us, but we are a scrypt pool that pays in Ethereum (among other currencies); we don't actually mine the Ethereum algorithm. You would have to configure your GPUs to use scrypt to connect to this pool, but honestly, if you're using GPUs, you should use them to directly mine Ethereum at another pool right now because it will be much more profitable than scrypt.
Re: New user help
Thanks for that info.
In your opinion what pool would you recommend for ethereum.
Something like what you got going on here. I really like your dashboard and stats.
Re: New user help
dwarfpool
