Proswitching doesn't work
I followed the GPU guide on prohashing to edit my eth.bat which works great, i configured my miner to track electricity which works great. the only issue is when i configure my miner to proswitching it says to replace "--server prohashing:3339" with "--server stratum+tcp://prohashing.com:3336" which doesn't work, i even tried "--server prohashing:3336" but it still doesn't work. Can someone please help me, thanks.
Re: Proswitching doesn't work
When you switch to proswitching in the worker configurator the algorithm at the top switches back to the default. Change it back, or more simply, stick with port 3339.Tallwalker wrote: ↑Sun May 23, 2021 12:19 pm I followed the GPU guide on prohashing to edit my eth.bat which works great, i configured my miner to track electricity which works great. the only issue is when i configure my miner to proswitching it says to replace "--server prohashing:3339" with "--server stratum+tcp://prohashing.com:3336" which doesn't work, i even tried "--server prohashing:3336" but it still doesn't work. Can someone please help me, thanks.
Ok i tried that and it still doesn't work, i get a message saying "Miner terminated, watchdog will restart process after 10 seconds". For reference, this is what my eth.bat file currently says,sonicrules wrote: ↑Sun May 23, 2021 1:02 pmWhen you switch to proswitching in the worker configurator the algorithm at the top switches back to the default. Change it back, or more simply, stick with port 3339.Tallwalker wrote: ↑Sun May 23, 2021 12:19 pm I followed the GPU guide on prohashing to edit my eth.bat which works great, i configured my miner to track electricity which works great. the only issue is when i configure my miner to proswitching it says to replace "--server prohashing:3339" with "--server stratum+tcp://prohashing.com:3336" which doesn't work, i even tried "--server prohashing:3336" but it still doesn't work. Can someone please help me, thanks.
"miner.exe --algo ethash --server stratum+tcp://prohashing.com:3339 --user Tallwalker --pass 1=8,a=ethash,w=150,p=0.11,n=Tallwalker
pause"
take off the stratum+tcp://
The pass should start with l=8 and not 1=8. That's a lowercase L. I get you, because it definitely looks like a one on the worker configurator page.Tallwalker wrote: ↑Sun May 23, 2021 5:37 pmOk i tried that and it still doesn't work, i get a message saying "Miner terminated, watchdog will restart process after 10 seconds". For reference, this is what my eth.bat file currently says,sonicrules wrote: ↑Sun May 23, 2021 1:02 pmWhen you switch to proswitching in the worker configurator the algorithm at the top switches back to the default. Change it back, or more simply, stick with port 3339.Tallwalker wrote: ↑Sun May 23, 2021 12:19 pm I followed the GPU guide on prohashing to edit my eth.bat which works great, i configured my miner to track electricity which works great. the only issue is when i configure my miner to proswitching it says to replace "--server prohashing:3339" with "--server stratum+tcp://prohashing.com:3336" which doesn't work, i even tried "--server prohashing:3336" but it still doesn't work. Can someone please help me, thanks.
pause"
I believe your command should be:
miner.exe --algo ethash --server stratum+tcp://prohashing.com:3339 --user Tallwalker --pass l=8,a=ethash,w=150,p=0.11,n=Tallwalker
pause
@sonicrules Ok thanks, I'll give that a try
