Gminer script Issues
anthunter
Post by anthunter » Sun Apr 25, 2021 3:54 pm
Hello and thought I would ask here first: I have been able to Successfully mine ethash using this: miner.exe --algo ethash --server prohashing.com:3339 --user pol --pass 4=8,c=ethereum,n=Worker1 pause.....but having issues using this : miner.exe --algo neoscrypt --server prohashing.com:3338 --user pol --pass 4=8,c=feathercoin,n=Worker1 pause ..........Getting algo not found. would love to mine some other coins what do I need to change to get it to work. Like I said the ethash works great. thanks in advanve.
PolakCrypto
Re: Gminer script Issues
Post by PolakCrypto » Sun Apr 25, 2021 10:53 pm
you need another miner like cryptodredge or something that supports neoscrypt mining. I dont believe gminer supports neoscypt algo for mining.
