Connection and Authorization Errors since 06:15 CET
----1st Miner, AMD GPU 8GB Card----------
1st Miner on eu.prohashing.com:
Lost Conenction to stratum server eu.prohashing.com:3339 or server not reachable
Same Miner with prohashing.com:
Worker xxx not authorized
Sometimes I receive jobs, often I got the above errors.
----2nd miner, NVidia 4GB Card----
I have a second miner with 4096 GB of RAM which I needed to configure using only 3072 and give password l=3
This one is completely not working, immediate looses conenction.
Error:
Connection Errors Detected
DISCONNECT (268)
6 seconds ago
The worker does not meet the DAG requirement of all available coins in the algorithm.
It used to work until today morning. What happend? Any CHanges? It was good for Expanses...
----debug info----
nslookup:
Nicht autorisierende Antwort:
Address:  5.254.118.160
Address:  50.220.121.209
ping:
Ping wird ausgeführt für eu.prohashing.com [5.254.118.160] mit 32 Bytes Daten:
Antwort von 5.254.118.160: Bytes=32 Zeit=34ms TTL=52
Antwort von 5.254.118.160: Bytes=32 Zeit=33ms TTL=52
Ping wird ausgeführt für prohashing.com [50.220.121.209] mit 32 Bytes Daten:
Antwort von 50.220.121.209: Bytes=32 Zeit=107ms TTL=49
Antwort von 50.220.121.209: Bytes=32 Zeit=105ms TTL=49
Miner:
lolminer 1.21
regards,
Dennis
						ETHash Issues | Connection error
				DennYoDeluxe
				Nosferatu272
Re: ETHash Issues | Connection error
#metoo xD
eu does not respond at all, main gives jobs above my gpu ram limit (4gb) and i cannot set to static (expanse or nekonium) cause it shows there is no such coin available to mine
				DennYoDeluxe
Still having huge connection losses, also one of my friends (other city, other provider, ...)
tcping -t eu.prohashing.com 3339
** Pinging continuously. Press control-c to stop **
Probing 5.254.118.160:3339/tcp - No response - time=2000.698ms
Probing 5.254.118.160:3339/tcp - No response - time=2015.427ms
Probing 5.254.118.160:3339/tcp - No response - time=2002.557ms
Probing 5.254.118.160:3339/tcp - No response - time=2019.314ms
Probing 5.254.118.160:3339/tcp - No response - time=2002.438ms
Probing 5.254.118.160:3339/tcp - No response - time=2002.313ms
I'll create a ticket about this and assign it to Chris for investigation.DennYoDeluxe wrote: ↑Mon Mar 22, 2021 5:34 pm Still having huge connection losses, also one of my friends (other city, other provider, ...)
