Greetings,
Would someone please clarify this? Consecutive as in, daily... no more than 6 being found by even if I have 20 miners... Or once I find 6 statically mining, period, that's it? How would it know? I've found 8 over two days part time mining, but none this morning. Wanted to understand the limitation more so. Thanks in advance and stay safe everyone!
Mining Notes
Verge only allows 6 consecutive blocks to be found for a single algorithm, which could lead to periodic disconnects when static mining when the limit is reached. Consider using Proswitching to maximize mining time instead.
XVG Limitation question
- Steven Godshall
Re: XVG Limitation question
Verge has multiple mining algorithms on its network, and their network limits that at most 6 blocks of the same algorithm can be found of the last 10 recent blocks.
If 6 of the last 10 blocks are found on the same algorithm, our pool set the algorithm into error because finding a 7th block would not confirm.
Perfect! Thank you kindly!Steven Godshall wrote: ↑Wed Mar 17, 2021 1:22 pm Verge has multiple mining algorithms on its network, and their network limits that at most 6 blocks of the same algorithm can be found of the last 10 recent blocks.
