Hi all,
I'm trying to setup a miner using the Ubuntu command line. I have already installed etheremin and I can run properly. However, I don't know how to connect it to prohashing I was reading https://www.vpnmentor.com/blog/what-is- ... u-mine-it/, that this command can be used:
ethminer -G -F http://eth-eu.dwarfpool.com/{WALLET ADDRESS}/{any_name} –cl-local-work 256 –cl-global-work 16384
However, I'm not use how should it look like for Prohashing.
Thanks a lot!
Setting up worker from Ubuntu command line
tugatrader
Re: Setting up worker from Ubuntu command line
Hello,
I'm mining in ubuntu 18 with the following command:
ethminer -G -P stratum+tcp://<username>:a=ethash@prohashing.com:3339
Hope this helps.
Cheers
Hope this helps.
Cheers
