Pool daily profitability not updating
Some1notu
Post by Some1notu » Sun Feb 07, 2016 8:53 pm
Not sure if you are aware, but the pool's daily profitability is not updating. Currently it is showing: 1MH/s: 0.00007413 BTC/day, which was the figure for Feb 4th.
Re: Pool daily profitability not updating
Post by Steve Sokolowski » Mon Feb 08, 2016 9:12 am
Thanks for pointing this out.
The profitability isn't being calculated, and when it is calculated is not correct, because the database is behind much of the time. We have been unable to determine so far why the database is so often behind. When the profitability calculator computes earnings, the database needs to be caught up in order to have the correct numbers.
We plan to continue looking at why the database is getting behind so frequently during the week.
