Mining Rig Rentals blocks ethash hashrate
Post by Steve Sokolowski » Sun Sep 13, 2020 10:45 am
Several miners have reported problems with connecting ethash miners to Prohashing. I found out this morning that Mining Rig Rentals, in an attempt to ward off abuse of their systems like has been done at Nicehash, has blocked ethash hashrate from mining Ethereum Classic at Prohashing (and presumably other pools as well.)
Some customers have either rented rigs from Mining Rig Rentals, or proxy rigs through Mining Rig Rentals because they like their dashboard features. If you proxy rigs through Mining Rig Rentals, you can get around this issue by connecting directly to Prohashing, which will also provide fewer rejected shares. Hopefully, you'll be satisfied with the improved design of the new website. If you're renting ethash hashrate through Mining Rig Rentals, then unfortunately there's not much we can do.
This issue does not affect any other algorithms than ethash.
arie137
Re: Mining Rig Rentals blocks ethash hashrate
Post by arie137 » Tue Jan 05, 2021 5:10 pm
So, you support mining rig rentals for other algos?
Post by Steve Sokolowski » Tue Jan 05, 2021 9:16 pm
We support Mining Rig Rentals for all algorithms.
You should contact them for more information about which algorithms they allow to be directed towards our servers. Any algorithms that aren't functioning are entirely up to them.
