Login
Dagere76
Login
Post by Dagere76 » Tue May 19, 2020 8:13 pm
I was able to login to site earlier and now Everytime I login to check my dashboard it just keeps sitting there and wants me to recheck the captcha? I setup two step authentication earlier and it worked fine, but I can't even login to check my workers. I have tried several different browsers and different IP addresses from VPNs.
MapledLeif
Re: Login
Post by MapledLeif » Tue May 19, 2020 8:29 pm
Same issue here. This issue has only been since the upgrade.
edwardcsouza
Re: Login
Post by edwardcsouza » Tue May 19, 2020 8:40 pm
I dont haver 2FA. ALL time that i try to login, the site stay processing. I try to request a New password and got from site that my accout do not exist.
Dagere76
Re: Login
Post by Dagere76 » Tue May 19, 2020 8:41 pm
MapledLeif wrote: Tue May 19, 2020 8:29 pm Same issue here. This issue has only been since the upgrade.
Has anyone said if we have to create a new account or anything?
MapledLeif
Re: Login
Post by MapledLeif » Tue May 19, 2020 9:03 pm
I just tried again now and it's working properly. Works with both Safari and Chrome.
Hockey_mike15
Re: Login
Post by Hockey_mike15 » Tue May 19, 2020 9:46 pm
MapledLeif wrote: Tue May 19, 2020 9:03 pm I just tried again now and it's working properly. Works with both Safari and Chrome.
Is it still working for you?? My miner shows its hashing but the website does not load
MapledLeif
Re: Login
Post by MapledLeif » Tue May 19, 2020 10:09 pm
Hockey_mike15 wrote: Tue May 19, 2020 9:46 pm
Yes, still working as it should.
