Internal getBalanceUpdates() wamp error return to API subscription attempt
Fern
Post by Fern » Sun Sep 29, 2019 6:38 am
Hi!
Doing some 3rd party monitoring tools integration, I found that all functions and topics work except for balance status and updates
I get the following error when trying to call
f_all_balance_updates
and
balance_updates_[apiKey]
Potentially unhandled rejection [1] {"error":"wamp.error.runtime_error","args":["getBalanceUpdates() takes exactly 2 arguments (1 given)"],"kwargs":{}} (WARNING: non-Error used)
Not sure what that 2nd arg is, do you guys have a public repo of this implementation? So I can answer these questions myself in the future.
Thanks!
Re: Internal getBalanceUpdates() wamp error return to API subscription attempt
Post by Steve Sokolowski » Sun Sep 29, 2019 7:30 am
Fern wrote: Sun Sep 29, 2019 6:38 am Hi!
and
Thanks!
Hi Fern,
Could you post some of the code around the area where you're making this call? What language are you using? A few lines of code will assist in trying to reproduce this problem.
Thanks!
Fern
Post by Fern » Sun Sep 29, 2019 9:11 am
Of course! it's a fork of KaptainKrayola's JS implementation:
This is my extended/forked version i'm using and getting the error from: https://github.com/fermelone/prohashing ... r/index.js
It surprises me that it talks about 2 args when there's no indication of more than one args to be passed in your help page.
I then use that implementation like this: https://github.com/fermelone/prohashing ... E.md#usage
Thanks for helping Steve!
Post by Steve Sokolowski » Mon Sep 30, 2019 12:59 pm
Fern wrote: Sun Sep 29, 2019 9:11 am Of course! it's a fork of KaptainKrayola's JS implementation:
Hi Fern,
I installed Node and tried to get your code to work, but it seems to hang after
(node:8696) Warning: Setting the NODE_TLS_REJECT_UNAUTHORIZED environment variable to '0' makes TLS connections and HTTPS requests insecure by disabling certificate verification.
I think the problem is that I'm not creating the object the same way you are. Could you send me the code you're using to create the object, especially the "config" parameter? If the "config" object contains personal information, then please submit or update a support ticket with it instead.
