Over the past weekend, I have been noticing the same thing for my Titans. Bouncing the miner process brings them back into line temporarily, but then they fail testing again and go red until I bounce them. The hashrate issue should definitely take precedence; just wanted to get this noted and see if anyone else is having this issue.tradewiz wrote:I recently have had issues with my workers becoming "red" in the worker list and get the error this miner is not responding got work restart etc. I did not get that before. ...
Work Restart Testing
Re: Work Restart Testing
Problem noted. Thanks kires.
Unfortunately, for some reason we've been overloaded with problems all of a sudden. In addition to the slippage problem which we think was resolved, and that payout issue, we now have a bad luck problem, which seemed to start suddenly last week. I wonder if it is related to the hashrate problem and to this issue.
The bad luck problem will have to push this one back, but I'm hoping that we discover that the problems are related in some way.
