IOST address problem
XXXJAYXXX
Post by XXXJAYXXX » Mon May 27, 2019 11:12 am
I keep getting a notification telling me to update my IOST address to a mainnet address.. I have tried several times with different formats and different wallets... the system will not accept a mainnet address for IOST. This is also causing the issue of not being able to update/modify ALL payout address's.. as the IOST error causes all other info to not be saved. Please fix this.. would be nice to get that IOST payout after months of it being locked on the site...
Site Admin
Re: IOST address problem
Post by Chris Sokolowski » Wed May 29, 2019 7:12 am
I apologize for the frustration. The website was still validating IOST addresses as if it were an Ethereum token, which is why you couldn't enter one of the new chain addresses. I have fixed this and you now should be able to enter the new address. Please let me know whether it works now.
XXXJAYXXX
Post by XXXJAYXXX » Wed May 29, 2019 9:36 pm
Hi Chris, The format for the address has updated and now shows "Address" and "Destination tag"... however.. it will still not accept the IOST address format.. I have tried 2 different address's including the bissiost main wallet for voting.. and a huobi wallet as well (Huobi wallet is recommended on the IOST website).. Both of these addresses should work.. but both give me the same error.
Post by Steve Sokolowski » Fri May 31, 2019 8:59 am
XXXJAYXXX wrote:Hi Chris, The format for the address has updated and now shows "Address" and "Destination tag"... however.. it will still not accept the IOST address format.. I have tried 2 different address's including the bissiost main wallet for voting.. and a huobi wallet as well (Huobi wallet is recommended on the IOST website).. Both of these addresses should work.. but both give me the same error.
Please submit a support ticket about this issue. I think that this may be a bug in the system. Once you submit a ticket, the bug can be tracked and assigned to Vance for resolution as soon as possible. Thanks!
XXXJAYXXX
Post by XXXJAYXXX » Sat Jun 01, 2019 1:53 pm
I submitted a support ticket months ago... never got a reply....
Post by Steve Sokolowski » Sat Jun 01, 2019 7:59 pm
XXXJAYXXX wrote:I submitted a support ticket months ago... never got a reply....
As far as I'm aware, the queue was at zero two months ago. Are you sure that you didn't miss the reply in your inbox?
XXXJAYXXX
Post by XXXJAYXXX » Mon Jun 03, 2019 11:45 am
Ticket submitted April 16th. First response was 5 days ago on May 29..
Post by Steve Sokolowski » Mon Jun 03, 2019 1:54 pm
I'll bring this forum post to Chris's attention and he will respond as soon as possible.
Post by Steve Sokolowski » Mon Jun 03, 2019 3:01 pm
I talked with Chris. This token was discontinued because it moved from ERC20 to a separate blockchain, and we don't anticipate demand being high enough to justify the cost of implementing the new system.
You will have to talk with Chris about a final manual payout.
