Monero daemon went into error
Post by Steve Sokolowski » Mon Apr 22, 2019 10:47 am
The Monero daemon went into error for an unknown reason this morning. We're investigating the issue, and hope to find out more information soon.
Re: Monero daemon went into error
Post by Steve Sokolowski » Mon Apr 22, 2019 11:12 am
Chris attempted to restart the server where the Monero client is failing, and the reboot failed. It will be several hours before someone is present at the hosting site to troubleshoot the issue.
Until then, Monero, Lyra2REv3, and about 50 coins on other algorithms will be unavailable for mining and payouts.
Post by Steve Sokolowski » Mon Apr 22, 2019 11:52 am
This issue has been resolved. Thanks for your patience. The cause of the problem was that there was a Monero daemon upgrade. We restarted the servers first thinking the client had crashed, and some critical linux updates needed to be installed that caused the servers to take a long time to start up.
