curiosity
curiosity
i finally got my Bakial g28 to work with prohashing! woo hoo!
dumb question alert!
on first 3 hours it was hashing at 45ghz. X11 algo PPS
now it is around 25 ghz on average. sometimes will go up to 30 ghz.
any body wanna let me know why the hash-rate drops so far over time? Please?
Thx in advance!
Thx in advance!
Re: curiosity
try e=off in password field
Re: curiosity
thanks but that dropped the hash rate to 19 ghz.
i guess i will keep looking.
Re: curiosity
Its a waste to use your G28 in PH because it uses only 1 algo (QUARK) out of the 7 algos its capable of.
The most profitable algo on G28 currently is Groestl and Qubit.
https://www.asicminervalue.com/miners/baikal/bk-g28
Re: curiosity
Thx for the tip!
I will give it a whirl!
is that a "live" update on profitability?
it does change so I would assume so.
Re: curiosity
Depends where you are looking.
At the top of the forums, yes.
At the top of the charts page, yes.
At the bottom of the charts page on "LIVE COIN STATUS", no, that one is delayed far as I know.
