Bitcoin Cash ABC issue resolved
While we were returning to State College after the Thanksgiving holiday, SHA-256 miners were disconnected because, for an unknown reason, the Bitcoin Unlimited Cash client started returning "invalid address" errors when we attempted to validate the addresses we were using for the coinbase transactions. The errors created issues with other algorithms because they caused high CPU load.
Chris has disabled Bitcoin Cash ABC until he can determine why this issue occurred suddenly. We anticipate that Bitcoin Cash will be back tomorrow. All other coins are already online.
In other news, the system restarted the past few mornings because of what we believe to be a failing motherboard. Chris will order another motherboard to replace it, but it will be at least a week or two before it arrives. The mining server is not using this motherboard, so the effect of a restart is that the website goes offline and shares are queued until Chris fixes the problem. Mining won't be affected if this motherboard issue happens again.
Re: Bitcoin Cash ABC issue resolved
in the meantime assume the bad motherboard is heat senstive and try to get more airflow around it. or better quality (cooler) air that is currently flowing (ie: pull chassis out from cramped spaces, racking)
Unfortunately, the location is in Philadelphia, so we aren't near the datacenter to be able to make these changes. This would have been a great idea if Chris had thought of it before leaving last week.dnprod wrote:in the meantime assume the bad motherboard is heat senstive and try to get more airflow around it. or better quality (cooler) air that is currently flowing (ie: pull chassis out from cramped spaces, racking)
bitcoincashSV is now more profitable than ABC and BTC , but is in error on prohashing, we're all missing out right now
The coinbase address for this daemon is invalid.
Chris will look into this issue shortly.GregoryGHarding wrote:bitcoincashSV is now more profitable than ABC and BTC , but is in error on prohashing, we're all missing out right nowCode: Select all
This issue has been resolved. It turns out that the cause of the issue is the same as the cause with Bitcoin ABC. The name "BitcoinCash" was hardcoded in three other places. This time, I searched for the name and changed it everywhere. I checked in the changes and a release will be issued later tonight.GregoryGHarding wrote:bitcoincashSV is now more profitable than ABC and BTC , but is in error on prohashing, we're all missing out right nowCode: Select all
