ReCAPTCHA problems
ReCAPTCHA problems
Did something change? I am unable to login half the time because the recaptcha is either not accepting any responses or is so slow to be barely useable. I went through 20 recaptha pages and it never let me login. What is going on?
Re: ReCAPTCHA problems
dont be a bot
That would definitely solve the problem! But it happens on my phone, and every computer I try, even on different networks, so it is very frustrating.GregoryGHarding wrote:dont be a bot
maybe someone on your network has failed the recaptcha too often
Can you specify which page you are on?derbagni wrote:Did something change? I am unable to login half the time because the recaptcha is either not accepting any responses or is so slow to be barely useable. I went through 20 recaptha pages and it never let me login. What is going on?
Any screenshots?
Could you post a screenshot of the issue you're having, so that we can begin an investigation?derbagni wrote:Did something change? I am unable to login half the time because the recaptcha is either not accepting any responses or is so slow to be barely useable. I went through 20 recaptha pages and it never let me login. What is going on?
if you fail so many, or your ip subset has had issues in the past getting a correct captcha, google likes to throw tests at you constantly, try using google chromes incognito mode, it could be a tracked cookie by google telling recapcha your a robot
This fixed it. I generally use a VPN so that could be part of it, but I could also have a cookie causing problems. It is just a bit weird that it is so many different devices that have different IPs and browswers. Either way, Incognito mode worked like a charm and I passed on the first try without it throwing 50 more at me.GregoryGHarding wrote:if you fail so many, or your ip subset has had issues in the past getting a correct captcha, google likes to throw tests at you constantly, try using google chromes incognito mode, it could be a tracked cookie by google telling recapcha your a robot
I will clean up my browser cookies and see if that makes a difference as well.
Thanks!
