CN8 minng
CN8 minng
CryptoNightV8 giving me a lot of rejects an no shares . error below don't forget Cn8 can't be mined with ASIC,
GPU and CPU Only .
I'm using GPU .
IT''s not my GPU or the software miner because it all works fine on other CN8 pools .
"A bug in the mining server prevented processing this share."
GPU and CPU Only .
I'm using GPU .
Re: CN8 minng
I'll forward this message to Vance for further review.nukepower wrote:CryptoNightV8 giving me a lot of rejects an no shares . error below don't forget Cn8 can't be mined with ASIC,
GPU and CPU Only .
I'm using GPU .
Re: CN8 minng
Looking good all shares accepted with some rejects which is normal,after the fix
thanks again !!!!
edit: rejects are low enough to make them normal so won't be reporting it unless they jump up a lot .
Thanks
thanks again !!!!
Thanks
Re: CN8 minng
hello, i throw 10k hash on this pool, however i noticed i am getting sometimes error.
[2018-11-02 21:14:54] Pool accepted result 0x000382FA
[2018-11-02 21:14:54] Pool accepted result 0x00019355
[2018-11-02 21:14:55] Pool accepted result 0x0002F093
[2018-11-02 21:14:56] Pool accepted result 0x00006BAE
[2018-11-02 21:14:59] Pool accepted result 0x00018C5D
[2018-11-02 21:14:59] Pool accepted result 0x00010168
[2018-11-02 21:15:07] Pool difficulty: 32767
[2018-11-02 21:15:07] Pool sent a new job (ID: 1e755f)
[2018-11-02 21:15:08] Pool rejected result 0x00004173 (miner is using an incorrect algorithm.)
[2018-11-02 21:15:08] Pool rejected result 0x00002FCF (miner is using an incorrect algorithm.)
[2018-11-02 21:15:09] Pool rejected result 0x000108FA (miner is using an incorrect algorithm.)
[2018-11-02 21:15:14] Pool accepted result 0x0001AD29
[2018-11-02 21:15:15] Pool accepted result 0x00003702
and this is repeating i think for every job sent to my miner, so that means im getting less shares, so less reward. please fix asap.
im using SRBMiner 1.6.9, w10, amd driver 18.9.2
EDIT: OK, I THROW 35K Hash here, but it showing only 31k and all get these kind errors as above.
Re: CN8 minng
Vance is resolving this issue as I write. There is no indication that the issue causes any lost money, however. The error message appears to be incorrect; these shares are stale.keksik wrote:hello, i throw 10k hash on this pool, however i noticed i am getting sometimes error.
Re: CN8 minng
ok thank you for info, ill check later how it is going and if my hash increase a bit.
Re: CN8 minng
today i woke up and checked my miners, all are connected, but all of them got error
[2018-11-03 09:39:55] Pool rejected result 0x0040AEFB (stale share)
[2018-11-03 09:39:55] Pool rejected result 0x00316A57 (stale share)
[2018-11-03 09:39:56] Pool rejected result 0x000D83C6 (stale share)
[2018-11-03 09:39:56] Pool rejected result 0x007EB852 (stale share)
[2018-11-03 09:39:56] Pool rejected result 0x002A0814 (stale share)
[2018-11-03 09:39:59] Pool rejected result 0x003C3F5D (stale share)
[2018-11-03 09:39:59] Pool rejected result 0x0019CF4B (stale share)
[2018-11-03 09:39:59] Pool rejected result 0x0064E68B (stale share)
[2018-11-03 09:39:59] Pool rejected result 0x006973EC (stale share)
[2018-11-03 09:39:59] Pool rejected result 0x005FFBBE (stale share)
[2018-11-03 09:40:00] Pool rejected result 0x0058904B (stale share)
[2018-11-03 09:40:00] Pool rejected result 0x006AED47 (stale share)
[2018-11-03 09:40:00] Pool rejected result 0x0059D041 (stale share)
[2018-11-03 09:40:00] Pool rejected result 0x005F16A4 (stale share)
[2018-11-03 09:40:00] Pool rejected result 0x004FF3CE (stale share)
[2018-11-03 09:40:00] Pool rejected result 0x00602469 (stale share)
[2018-11-03 09:40:00] Pool rejected result 0x0079551B (stale share)
[2018-11-03 09:40:01] Pool rejected result 0x0048F2DB (stale share)
[2018-11-03 09:40:01] Pool rejected result 0x0052F6ED (stale share)
[2018-11-03 09:40:01] Pool rejected result 0x00103924 (stale share)
[2018-11-03 09:40:01] Pool rejected result 0x00788167 (stale share)
[2018-11-03 09:40:01] Pool rejected result 0x005CE161 (stale share)
[2018-11-03 09:40:01] Pool rejected result 0x0055D3BA (stale share)
[2018-11-03 09:40:01] Pool rejected result 0x0038F82F (stale share)
[2018-11-03 09:40:02] Pool rejected result 0x004E17CC (stale share)
[2018-11-03 09:40:02] Pool rejected result 0x00192CE6 (stale share)
[2018-11-03 09:40:02] Pool rejected result 0x00217FA1 (stale share)
[2018-11-03 09:40:02] Pool rejected result 0x00004A13 (stale share)
please fix, all my rigs are doing this now
edit: i turnet of mining and turned it on again, it started hashing and sending correct shares,but after 1minutes it is ahppening again, all shares rehected and all miners.
Re: CN8 minng
There must have been a bug that was introduced in last night's upgrade to resolve the "incorrect algorithm" issue.keksik wrote:today i woke up and checked my miners, all are connected, but all of them got error
Unfortunately, we have insufficient manpower on weekends for us to work on multiple tasks at once, and today I'm focusing on the equihash "Sapling" protocol fixes today and have other critical issues that need to be resolved tomorrow. We hope to have a fix for this bug on Monday afternoon.
Re: CN8 minng
I was successfully able to resolve the Sapling changes issue. That means I might be able to get to the CryptoNight issue more quickly than I had anticipated. I don't think that the CryptoNight issue is related to yesterday's changes, though, which might mean this is going to take a lot more investigation.
Last edited by Steve Sokolowski on Sat Nov 03, 2018 12:18 pm, edited 1 time in total.
PolakCrypto
Re: CN8 minng
Yeah its def a different pattern, I left my miner on while i was sleeping about 6-7 hrs and it was going good when I fell asleep then I Wokeup and it was like 60% rejections.....earnings reflect that accurately as well.
Thanks for woring on it..only been 3-4 days since CN mining has been introduced on PH...so making quick progress.
