E3 miners update
E3 miners update
I'm pleased to be able to provide an update on the E3 miners issue.
Unfortunately, it turns out that E3 miners are unsupported because they use a different protocol. There are about five different stratum protocols for ethash, and E3s don't use the NiceHash stratum protocol, which we currently support. The E3 protocol is described at https://github.com/sammy007/open-ethere ... STRATUM.md.
Supporting this protocol has some prerequisites that will be satisfied by implementing Monero mining. Therefore, Vance will continue his work on Monero mining, which he's doing now, and which remains on schedule to be available by November. As Christmas approaches, he will work on adding support for E3s.
We apologize for this issue. Other ETH miners can continue mining as normal, and hopefully the E3 firmware will be updated to also support this protocol. If it is not, then we should have support for E3s available within two months.
Re: E3 miners update
OK thanks! will keep monitoring, will mine ETH directly until then!
Thanks Steve. For getting to the bottom of this and letting us know.
Hey Steve, any plans to support the stratum required for the E3s? Would be great
We've already added support. You should use static coin mining, with "c=," if you end up with a lot of rejected shares.greenhorn0815 wrote:Hey Steve, any plans to support the stratum required for the E3s? Would be great
Let me know how things go!
Awesome work Steve! Thanks!
Update, it did need to be set c= in this case ethereum to stop delivering rejects, weird behavior tho is the auto diff engine not set correctly?
update: Miners reboot every 2-3 hours, all together means a stratum command triggering it.
Workers
56f31d0c-f80d-4e17-8ea5-4f8b0beec314
e01bf926-9fba-4338-9c1a-96a7175645ba
1219db6e-031c-43c3-917a-33bb05d0e705
If log relevant to you, i will keep them on till i get your verdict.
Workers
I'll bring this message to the attention of Vance. However, he's working on adding support for USDC and Tether to the pool, and therefore it could be some time before he is able to address the issue.greenhorn0815 wrote:update: Miners reboot every 2-3 hours, all together means a stratum command triggering it.
Workers
Yeah, no rush
Thank you!
