Why the differences in hashing power and hashing accepted ?
purequality4u
Post by purequality4u » Thu Sep 24, 2015 9:34 pm
My 2 Zeusminer thunder X3 show 30 Mh/s average each one in cgminer, but in the page show only 24 MH/s average for Zeus01 and 19MH/s on Zeus02.
Is it normal ? or can I change some parameters in cgminer ???
valta4065
Re: Why the differences in hashing power and hashing accepted ?
Post by valta4065 » Fri Sep 25, 2015 2:36 am
I use 1 of those thunders and where your password is I use d=4096 and seems to run about the same as cgminer show,I also have clk speed at 348 rather than 328 it should be
Site Admin
Post by Chris Sokolowski » Fri Sep 25, 2015 5:28 am
I think the most likely scenario is that your miners are averaging the hashrate over a different timespan than the site is. Our reported hashrate is for the last 15 minutes, whereas if I recall correctly, cgminer reports the average hashrate since the miner was turned on. You could have just had an unlucky period of time. Do you have a high latency connection? You could be submitting many stale shares, which could also account for the disparity in hashrate.
As far as tuning, Our Thunder X6's found the best hashrate at d=2048, although d=4096 is also a good choice if you want to reduce bandwidth used. The automatic work restart testing worked the best for those miners, so I would not recommend setting a static restart interval.
purequality4u
Post by purequality4u » Fri Sep 25, 2015 4:52 pm
ok, I´m trying to use -p d=4096 n=Zeus01 but the cgminer give me an error on parameters
Site Admin
Post by Chris Sokolowski » Sat Sep 26, 2015 4:30 pm
With cgminer you need to use quotes or else it will assume the second password argument is another command line parameter. So use -p "d=4096 n=Zeus01" instead.
