Tag coin
Tag coin
I set Tagcoin to auto pay yet it has not payed for days now is there a minimum even at auto daily?
- Chris Sokolowski
- Site Admin
Re: Tag coin
We don't have a minimum payout amount if you select "ignore payout threshold;" however, some coin networks do have a minimum transaction size that might reject a small payout. I will look into Tagcoin further in a few hours - after the payouts auto-execute.
Re: Tag coin
Okay thanks well I have 8 Tag now for days, I will add more to it and see if that helps for auto daily
Re: Tag coin
Well that did not help to mine for more Tag, Still no payout and is stuck for some reason
Re: Tag coin
Well I changed payout address to go to cryptsy and I know it works because I sent what I had from my wallet to there, Tag is sticking on your end for some reason
Re: Tag coin
I'll talk with Chris and try to get a final resolution on this today, one way or the other. If we can't fix it, we'll disable Tagcoin permanently, because people shouldn't have to wait for so long to get paid.
I'll get back to you later today.
Re: Tag coin
Okay thanks and yes 12 Tag should be paying and still did not
- Chris Sokolowski
- Site Admin
Re: Tag coin
Cryptsy is not processing our Tagcoin withdrawals. I cannot pay out because I can't get the coins from the exchange to our wallet. I have submitted a support ticket to Cryptsy and am waiting for their response.
Re: Tag coin
worked for me the other day when I sent tag from my own wallet to cryptsy but they are a little slow on all coins it seems like
- Chris Sokolowski
- Site Admin
Re: Tag coin
The withdrawal is still pending. Unfortunately I can't do much until they resolve the issue. I received the following reply for my support ticket:
Hello Christopher,
We do apologize for the late response. We are currently experiencing delays with TAG withdrawals. Our technical team is working on this issue. We will inform you soon as the issue has been resolved. If you would like to cancel the withdrawal while we are working on the issue, please let us know. We are sorry for the delay and thank you for your patience.
Sincerely,
Gretchen
Cryptsy.com
