Small Website Improvements
nomad64
Post by nomad64 » Thu Sep 03, 2015 3:02 pm
I have noticed that when logging in, the 'Login' button stays greyed out until it detects typing in both the username and password boxes. This causes problems with my password management software (KeePass) since it automatically detects the fields and fills them; however, it does so in such a way that the 'Login' button stays greyed out. Is there a way that could be changed? My current work-around has been to manually copy/paste those fields.
Additionally, is it possible to make a version of the site more mobile friendly? While the Earnings page does render mostly-correct on my Android phone, the 'Current Mining' speedometer doesn't appear to function, and the page itself takes a while to load.
I hope I explained those correctly. Let me know if you have any questions.
Thanks!
tucsondirect
Re: Small Website Improvements
Post by tucsondirect » Sat Sep 05, 2015 4:45 pm
Just click in one of the fields and it should go for you :) or put your cursor in one field and hit enter
