I plugged my new Bitmain - Antminer S4 to your hashing pool and I am not sure if everything is in proper order.
Can someone please help me out?
I used this domain - > prohashing.com:3333
my username from my site registration (not forum) -> thxxxxxxy1
password - left blank.
I see messaged like this in my dashboard. I am using an ANTMINER - by BITMAIN - S4 version
Primary coin you mined Litecoin
Block number 8191XX
Block hash dCKfXHGNoDVG6dSSgtA9VLBsDPzHrRPWjaFWPA51dWF
Target difficulty 1024
Submitted difficulty
Pool status Rejected (Miner is using an incorrect algorithm.)
Blocks found No blocks found
IP address 97.68.53.50
Work start time 7/20/2015 4:38:00 PM
Submission time 7/20/2015 4:38:00 PM
Mining duration 0.01 seconds
Work restart time 0.358 seconds
Work restart efficiency 98.83%
Average work restart efficiency
New User
- tucsondirect
Re: New User
You are attempting to mine Scrypt coins with A SHA-256 miner, might i suggest you seek out an appropriate Sha-256 pool for your miner?
- Chris Sokolowski
- Site Admin
Re: New User
tucsondirect is correct. You will need to find a SHA-256 pool on which to use that miner as at the moment Prohashing does not support SHA-256.
