Ok I have a thunder and when I started hashing I get very few accepted shares and and a lot of "stratum from pool 0 requested work restart.
I have no idea how to fix this issue. Any help would be great
somthing wrong with Hashing
Re: somthing wrong with Hashing
Hi vtec,
Welcome!
Most likely, you're seeing work restart testing. The first six shares submitted are given a very low difficulty, in order to determine how fast your miners are and what your ping time is. This information is then used to determine the optimal coins for you to mine in order to make the most money.
After the six shares, then your miners should begin mining at a normal difficulty. Please inform me if that isn't the case.
Thanks,
-Steve
Welcome!
Thanks,
-Steve
