A little confused? Solo mining...
markdil
Post by markdil » Wed May 16, 2018 10:06 am
I am fairly new to mining. I have been mining LiteCoin solo. It seems I constantly get blocks from other coins with difficulties much higher than LiteCoin. But NEVER a LiteCoin block. Probability tells me I should. Maybe I am not understanding something. Could someone explain what is incorrect in my thought process?
Thanks!
ryguy
Re: A little confused? Solo mining...
Post by ryguy » Wed May 16, 2018 10:34 am
If you're getting blocks that aren't litecoin you're not solo mining.
markdil
Post by markdil » Wed May 16, 2018 10:38 am
It shows solo mining.
Here is my password:
a=script c=litecoin m=solo d=524288
ryguy
Post by ryguy » Wed May 16, 2018 10:39 am
What are some of the other blocks you're getting? They might be the merged mining blocks.
Also just for reference, not that I think it would matter, but it's scrypt, not script
markdil
Post by markdil » Wed May 16, 2018 10:46 am
Leafcoin, Viacoin, Pesetacoin. I got five blocks in five minutes. Wish I could post a screenshot. Not sure how.
Something is not right.
I know it is Scrypt, my iPad loves to correct me.
ryguy
Post by ryguy » Wed May 16, 2018 10:50 am
If you're on an iPad I believe if you hold the sleep/wake button and click the home button you can take a screenshot.
I think those are merged mining blocks, which would be fine to get solo.
markdil
Post by markdil » Wed May 16, 2018 10:52 am
I have the screenshot, the forum won’t let me attach an image. Here it is:
http://rc9.net/blocks.jpg
If it is possible to find that many blocks, in that short of time, with those difficulties, why no LiteCoin?
ryguy
Post by ryguy » Wed May 16, 2018 10:56 am
It looks fine to me. You're getting merged mining blocks.
markdil
Post by markdil » Wed May 16, 2018 10:59 am
But why no LiteCoin? Difficulty of LiteCoin is 10,420,961.
Look at the difficulties of the blocks I found!!
Always other harder blocks, NEVER LiteCoin. Probability tells me otherwise. Something is amiss.
ryguy
Post by ryguy » Wed May 16, 2018 11:05 am
Well I don't know what your hashrate is, but difficulty isn't the only factor in finding blocks.
However, as an example, presently if you have 100 GH/s solo mining LTC you'd likely find on average 1 block every 5 days. Viacoin with the same hashrate would get about 4 blocks per day. Also I think the reported difficulties are wrong. Viacoin's present difficulty is about 585K.
