D3 and DR100 can not connect to the ore pool after the reboot is low
Hello, D3 and DR100 can not connect the ore pool after restart after power failure.
Re: D3 and DR100 can not connect to the ore pool after the reboot is low
Use the network diagnostics of the D3 User Interface.
See if you can ping the pool from the miner.
Have you shut down all the equipment on the network? routers, modems, unplugged them and waited 5 mins then booted them all back up?
