So can i mine here with quark?
JiveTonto
Post by JiveTonto » Mon May 11, 2015 7:46 pm
So I currently mine Dime at http://dime.npool.org:2200/static/
My question is can i mine dime here and get payed out in dime or would you just pay a rate on the mhs like you do with scrypt
Site Admin
Re: So can i mine here with quark?
Post by Chris Sokolowski » Mon May 11, 2015 9:35 pm
Right now we only support scrypt, so you couldn't mine DIME directly since it's a quark coin. We hope to support other algorithms in the future, in which case you could connect a Quark miner to directly mine DIME, but we don't have an estimate on when we will have other algorithms implemented.
kires
Post by kires » Mon May 11, 2015 10:29 pm
Is scrypt-n one of those future algos by any chance?
Site Admin
Post by Chris Sokolowski » Tue May 12, 2015 12:59 am
It certainly could be. We need to pick one algorithm to work on first, and we chose to focus on X11 since it has the most coins. Just like with the exchanges, adding the second algorithm is the most challenging since it requires the most changes to the server and database. The third and any subsequent algorithms should then be easy to implement.
