Average Work Restart Efficiency
kires
Post by kires » Fri May 08, 2015 8:54 am
Not a show stopper by any means, but I just noticed that my average work restart efficiency is at 100.10%. On the one hand, this is really great for me since I'll apparently be receiving a bit more than I'm entitled to. But on the other hand, wtf?
Re: Average Work Restart Efficiency
Post by Steve Sokolowski » Fri May 08, 2015 11:46 am
Hi kires,
I'm replying again because, for some reason, the first post seems to have disappeared.
Are you referring to the average work restart penalty? If so, then a penalty greater than 100% indicates that your miners are more efficient than the average miner. The pool rewards you with a bonus because you are increasing profitability.
If that's not what you mean, then let us know.
-Steve
kires
Post by kires » Fri May 08, 2015 11:52 am
You are quite correct. I was misreading it. Thanks for clearing that up.
