Please consider the addition of btcp to the equihash coins mined.
https://coinmarketcap.com/currencies/bitcoin-private/
https://btcprivate.org/pools.html
Bitcoin Private equihash
Re: Bitcoin Private equihash
Chris considered adding this coin, but it uses different equihash parameters than the other equihash coins. That means that we can't switch between it and the other equihash coins automatically. It's essentially a new algorithm, and would be the only coin on the algorithm.zafar177 wrote:Please consider the addition of btcp to the equihash coins mined.
Interesting. You guys are so busy but if you have the time please take a look at these other suggestions to expand the equihash coin list.
1) Snowgem
https://www.coingecko.com/en/coins/snowgem
2) Votecoin
https://www.coingecko.com/en/coins/votecoin
3) Commercium
https://www.commercium.net
4) Safecoin
https://safecoin.org
1) Snowgem
2) Votecoin
3) Commercium
4) Safecoin
We'd love to add new coins. The limitation in adding them is usually that no exchange with API calls we need supports them. If you could look up whether these coins are eligible, here are the two criteria. They can either be listed on bittrex, cryptopia, ccex, novaexchange, poloniex, gate.io, binance, hitbtc, bleutrade, or livecoin - or, they can be listed at a different exchange that has all seven of the following API functions available: deposit, withdrawal, buy, sell, get balance, get whether the wallet is locked or not, and get block number of the exchange's daemon.zafar177 wrote:Interesting. You guys are so busy but if you have the time please take a look at these other suggestions to expand the equihash coin list.
1) Snowgem
2) Votecoin
3) Commercium
4) Safecoin
Does Votecoin qualify?
Public Api
GET GetCurrencies
Description
Uri: https://tradesatoshi.com/api/public/getcurrencies
Parameters: None
"success": true,
"message": null,
"result": [
"currency": "BOLI",
"currencyLong": "Bolivarcoin",
"minConfirmation": 3,
"txFee": 0.00000000,
"status": "OK"
"currency": "BTC",
"currencyLong": "Bitcoin",
"minConfirmation": 6,
"status": "OK"
GET GetTicker
Description
Uri: https://tradesatoshi.com/api/public/get ... et=LTC_BTC
Parameters:
market: The market name e.g. 'LTC_BTC' (required)
"success":true,
"message":null,
"result":{
"bid":0.01500000,
"ask":100.00000000,
"last":0.01000000,
"market":"LTC_BTC"
GET GetMarketHistory
Description
Uri: https://tradesatoshi.com/api/public/get ... C&count=20
Parameters:
count: The max amount of records to return (optional, default: 20)
"success": true,
"message": null,
"result": [
"id": 512,
"timeStamp": "2016-04-28T01:34:02.397",
"quantity": 0.00784797,
"price": 0.01000000,
"orderType": "Buy",
"total": 0.00007848
"id": 503,
"timeStamp": "2016-04-23T08:16:38.087",
"quantity": 0.00134797,
"price": 0.08555000,
"orderType": "Buy",
"total": 0.00011532
"id": 502,
"timeStamp": "2016-04-23T08:16:34.91",
"quantity": 0.00650000,
"price": 0.07900000,
"orderType": "Buy",
"total": 0.00051350
GET GetMarketSummary
Description
Parameters:
"success":true,
"message":null,
"result":{
"market":"LTC_BTC",
"high":0.01000000,
"low":0.01000000,
"volume":0.00784797,
"baseVolume":0.00007848,
"last":0.01000000,
"bid":0.01500000,
"ask":100.00000000,
"openBuyOrders":2,
"openSellOrders":7
GET GetMarketSummaries
Description
Uri: https://tradesatoshi.com/api/public/getmarketsummaries
Parameters: None
"success":true,
"message":null,
"result":[
"market":"TRAD_BTC",
"high":0.00000000,
"low":0.00000000,
"volume":0.00000000,
"baseVolume":0.00000000,
"last":0.00000000,
"bid":0.00000000,
"ask":0.00000000,
"openBuyOrders":0,
"openSellOrders":0
"market":"BUMBA_BTC",
"high":0.00000000,
"low":0.00000000,
"last":0.00000000,
"bid":0.00000000,
"ask":0.00000000,
"openBuyOrders":0,
"openSellOrders":0
GET GetOrderBook
Description
Uri: https://tradesatoshi.com/api/public/get ... h&depth=20
Parameters:
type: The order book type 'buy', 'sell', 'both' (optional, default: 'both')
depth: Max of records to return (optional, default: 20)
"success": true,
"message": null,
"result": {
"buy": [
"quantity": 0.00000000,
"rate": 0.01500000
"quantity": 1.00000000,
"rate": 0.00750000
"sell": [
"rate": 0.00756150
"rate": 0.00770000
"rate": 0.01000000
Private API
Authentication
Authenticated methods require the use of an api key and can only be accessed via the POST method.
Authentication Header
Authorization is performed by sending the following variables into the request authentication header:
API_PUBLIC_KEY + ':' + SIGNATURE + ':' + NONCE
Request Signature:
URI:
The uri endpoint e.g. https://tradesatoshi.com/api/private/getbalance
API_PUBLIC_KEY:
Your TradeSatoshi api key
POST_PARAMS:
JSON post parameters (base64 encoded)
NONCE:
Unique indicator for each request.
SIGNATURE:
API_KEY + "POST" + URI + NONCE + POST_PARAMS (signed by secret key according to HMAC-SHA512 method.)
POST GetBalance
Return information for a specific balance
Uri: https://tradesatoshi.com/api/private/getbalance
Parameters:
Currency: The currency of the balance to return e.g. 'BTC' (required)
"success":true,
"message":null,
"result": {
"Currency": "BTC",
"CurrencyLong": "Bitcoin",
"Avaliable": 49.00000000,
"Total": 53.00000000,
"HeldForTrades": 1.00000000,
"Unconfirmed": 1.00000000,
"PendingWithdraw": 1.00000000,
"Address": "1HB5XMLmzFVj8ALj6mfBsbifRoD4miY36v"
POST GetBalances
Return information for a all balances
Uri: https://tradesatoshi.com/api/private/getbalances
Parameters: None
"success":true,
"message":null,
"result":[{
"Currency": "BTC",
"Currency": "LTC",
"CurrencyLong": "Litecoin",
"Address": "3KBUuGko4H5ke7EVsq9B7PLK1c5Askdd7y"
POST GetOrder
Description
Uri: https://tradesatoshi.com/api/private/getorder
Parameters:
OrderId: The order to return (required)
"success":true,
"message":null,
"result":{
"Id": "18253",
"Market": "LTC_BTC",
"Type": "Buy",
"Amount": 100.00000000,
"Rate": 0.01000000,
"Remaining": 0.50000000,
"Total": 1.00000000,
"Status": "Partial",
"Timestamp": "2015-12-07T20:04:05.3947572",
"IsApi": true
POST GetOrders
Description
Uri: https://tradesatoshi.com/api/private/getorders
Parameters:
Market: The market name e.g. 'LTC_BTC' (optional, default: 'all')
Count: The maximum count of records to return (optional, deefault: 20)
"success":true,
"message":null,
"result": [{
"Id": "18253",
"Type": "Buy",
"Rate": 0.01000000,
"IsApi": true
"Id": "18253",
"Type": "Buy",
"Rate": 0.01000000,
"IsApi": true
POST SubmitOrder
Description
Uri: https://tradesatoshi.com/api/private/submitorder
Parameters:
Market: The market name e.g. 'LTC_BTC' (required)
Type: The order type name e.g. 'Buy', 'Sell' (required)
Amount: The amount to buy/sell (required)
Price: The price to buy/sell for (required)
"success":true,
"message":null,
"result":{
"OrderId": 343526,
"Filled":[24124,41284,57548]
POST CancelOrder
Description
Uri: https://tradesatoshi.com/api/private/cancelorder
Parameters:
Type: The cancel type, options: 'Single','Market','MarketBuys','MarketSells','AllBuys','AllSells','All'(required)
OrderId: The order to cancel(required if cancel type 'Single')
Market: The order to cancel(required if cancel type 'Market','MarketBuys','MarketSells')
"success":true,
"message":null,
"result": {
"CanceledOrders": [233544, 233545, 233546]
POST GetTradeHistory
Description
Uri: https://tradesatoshi.com/api/private/gettradehistory
Parameters:
Count: The maximum count of records to return (optional, default: 20)
PageNumber: The Pagenumber for maintain pagination (optional, default: 0)
"success":true,
"message":null,
"totalRecords":75,
"result": [{
"Id": "18253",
"Type": "Buy",
"Rate": 0.01000000,
"Fee": 0.00020000,
"Total": 0.99980000,
"IsApi": true
"Id": "18253",
"Type": "Buy",
"Rate": 0.01000000,
"Fee": 0.00020000,
"IsApi": true
POST GenerateAddress
Description
Uri: https://tradesatoshi.com/api/private/generateaddress
Parameters:
Currency: The currency to generate address for e.g. 'BTC' (required)
"success":true,
"message":null,
"result": {
"Currency": "LTC",
POST SubmitWithdraw
Description
Uri: https://tradesatoshi.com/api/private/submitwithdraw
Parameters:
Currency: The currency name e.g. 'BTC' (required)
Address: The receiving address (required)
Amount: The amount to withdraw (required)
"success":true,
"message":null,
"result": {
"WithdrawalId": 546474
POST GetDeposits
Description
Uri: https://tradesatoshi.com/api/private/getdeposits
Parameters:
Currency: The currency name e.g. 'BTC' (optional, default: 'all')
"success":true,
"message":null,
"result": [{
"Id": "436436",
"Currency": "BTC",
"Status": "Unconfirmed",
"Txid": "9281eacaad58335b884adc24be884c00200a4fc17b2e05c72e255976223de187",
"Confirmations": 0,
"Id": "436437",
"Currency": "BTC",
"Status": "Confirmed",
"Txid": "6ddbaca454c97ba4e8a87a1cb49fa5ceace80b89eaced84b46a8f52c2b8c8ca3",
"Confirmations": 12,
POST GetWithdrawals
Description
Uri: https://tradesatoshi.com/api/private/getwithdrawals
Parameters:
"success":true,
"message":null,
"result": [{
"Id": "436436",
"Currency": "BTC",
"Fee": 0.00040000,
"Txid": null,
"Confirmations": 0,
"IsApi" : false
"Id": "436437",
"Currency": "BTC",
"Fee": 0.00040000,
"Address": "3KBUuGko4H5ke7EVsq9B7PLK1c5Askdd7y",
"Status": "Complete",
"IsApi" : false
POST SubmitTransfer
Description
Uri: https://tradesatoshi.com/api/private/submittransfer
Parameters:
currency: The currency symbol of the coin to transfer e.g. 'DOGE' (required)
username: The TradeSatoshi username of the person to transfer the funds to.(required)
Amount: The amount of coin to transfer e.g. 251.00000000(required)
"success": true,
"message": null,
"result": {
"data": "Successfully transfered 251.00000000 DOGE to XYZ"
Sorry for copy and paste but my understanding of API commands is zero.
Public Api
GET GetCurrencies
Description
Parameters: None
"success": true,
"message": null,
"result": [
"currency": "BOLI",
"status": "OK"
"currency": "BTC",
"status": "OK"
GET GetTicker
Description
Parameters:
"success":true,
"message":null,
"result":{
"bid":0.01500000,
"ask":100.00000000,
"last":0.01000000,
"market":"LTC_BTC"
Description
Parameters:
"success": true,
"message": null,
"result": [
"id": 512,
"orderType": "Buy",
"total": 0.00007848
"id": 503,
"orderType": "Buy",
"total": 0.00011532
"id": 502,
"orderType": "Buy",
"total": 0.00051350
Description
Parameters:
"success":true,
"message":null,
"result":{
"market":"LTC_BTC",
"high":0.01000000,
"low":0.01000000,
"last":0.01000000,
"bid":0.01500000,
"ask":100.00000000,
"openBuyOrders":2,
"openSellOrders":7
Description
Parameters: None
"success":true,
"message":null,
"result":[
"high":0.00000000,
"low":0.00000000,
"last":0.00000000,
"bid":0.00000000,
"ask":0.00000000,
"openBuyOrders":0,
"openSellOrders":0
"high":0.00000000,
"low":0.00000000,
"last":0.00000000,
"bid":0.00000000,
"ask":0.00000000,
"openBuyOrders":0,
"openSellOrders":0
GET GetOrderBook
Description
Parameters:
"success": true,
"message": null,
"result": {
"buy": [
"rate": 0.01500000
"rate": 0.00750000
"sell": [
"rate": 0.00756150
"rate": 0.00770000
"rate": 0.01000000
Private API
Authentication
Request Signature:
URI:
API_PUBLIC_KEY:
POST_PARAMS:
NONCE:
SIGNATURE:
POST GetBalance
Parameters:
"success":true,
"message":null,
"result": {
"Currency": "BTC",
POST GetBalances
Parameters: None
"success":true,
"message":null,
"result":[{
"Currency": "BTC",
"Currency": "LTC",
POST GetOrder
Description
Parameters:
"success":true,
"message":null,
"result":{
"Id": "18253",
"Type": "Buy",
"Rate": 0.01000000,
"IsApi": true
POST GetOrders
Description
Parameters:
"success":true,
"message":null,
"result": [{
"Id": "18253",
"Type": "Buy",
"Rate": 0.01000000,
"IsApi": true
"Id": "18253",
"Type": "Buy",
"Rate": 0.01000000,
"IsApi": true
POST SubmitOrder
Description
Parameters:
"success":true,
"message":null,
"result":{
"OrderId": 343526,
POST CancelOrder
Description
Parameters:
"success":true,
"message":null,
"result": {
Description
Parameters:
"success":true,
"message":null,
"totalRecords":75,
"result": [{
"Id": "18253",
"Type": "Buy",
"Rate": 0.01000000,
"Fee": 0.00020000,
"IsApi": true
"Id": "18253",
"Type": "Buy",
"Rate": 0.01000000,
"Fee": 0.00020000,
"IsApi": true
Description
Parameters:
"success":true,
"message":null,
"result": {
"Currency": "LTC",
POST SubmitWithdraw
Description
Parameters:
"success":true,
"message":null,
"result": {
POST GetDeposits
Description
Parameters:
"success":true,
"message":null,
"result": [{
"Id": "436436",
"Currency": "BTC",
"Confirmations": 0,
"Id": "436437",
"Currency": "BTC",
POST GetWithdrawals
Description
Parameters:
"success":true,
"message":null,
"result": [{
"Id": "436436",
"Currency": "BTC",
"Fee": 0.00040000,
"Txid": null,
"Confirmations": 0,
"IsApi" : false
"Id": "436437",
"Currency": "BTC",
"Fee": 0.00040000,
"IsApi" : false
POST SubmitTransfer
Description
Parameters:
"success": true,
"message": null,
"result": {
