usaer or email not exists?
3 hours ago (now 11:38am 25april2018 atlantic standard time) I signed into my account just fine, now It says wrong user , password, I press to recover and it says user/email does not exist, I signed up with new user, what happened to my old account?
Re: usaer or email not exists?
Unique username and password? Never used on any other sites?
Did you have 2FA enabled?
Check the caps lock button and the num lock?
What @CSZiggy said - also try turning your laptop off, clearning cookies.
If you miners are on-line, your account should be ok. Assume you use Authy
I have noticed that sometimes sites which use CloudFlare seem to interfere with each other (assume there is some competing JS which does not clear memory).
