Why Equihash Cannot Connect to Nicehash?
o51888
Post by o51888 » Tue Apr 24, 2018 11:30 pm
WHY??
Notice: Pool verificator may not be 100% accurate and may report pool being compatible while in fact it is not compatible or vice versa. Always discuss with pool operator if you encounter any issues with the pool verificator.
Pool host: prohashing.com
Pool port: 3333
Pool user: o51888
Pool pass: a=equihash d=4096
Algorithm: Equihash
Resolving pool host prohashing.com... OK
Establishing connection with proxy... OK
Establishing connection with pool 50.225.198.65:3333... OK
Sending mining.subscribe... OK
Sending mining.authorize... OK
Error: Result array size not 2.
Your pool is shown as incompatible therefore we encourage you to contact pool operator to make sure that the pool is using minimal/starting pool share difficulty which is compatible with our service (and thus compatible with today's miners), please send them following link: https://www.nicehash.com/help/which-min ... -supported. Thank you!
Close
