Congratulations to superminer A9sLWp9VHhbF!
I wanted to be the first to congratulate A9sLWp9VHhbF, who found the pool's first bitcoin block, worth $100858. It's block number 518644. Congratulations!
Re: Congratulations to superminer A9sLWp9VHhbF!
SUPER ...Congratulations to the WINNER !!! ...Continue the same way ...Steve Sokolowski wrote:I wanted to be the first to congratulate A9sLWp9VHhbF, who found the pool's first bitcoin block, worth $100858. It's block number 518644. Congratulations!
Awesome!
@A9sLWp9VHhbF Congratulations!!! my bank balance thanks you!
Steve, is there anyway to set an asic to mine Bitcoin as the main coin? It's not in the block explorer list.
a=sha-256 c=bitcoin oralim wrote:@A9sLWp9VHhbF Congratulations!!! my bank balance thanks you!
a=sha-256 c=bitcoin m=solo
Depending if you want to mine it solo or in the pool.
We don't have a block explorer for bitcoin because there are so many block explorers for that coin that adding another one wouldn't be very useful, and it would cost a lot to provide it. You can still mine bitcoins solo if you'd like, but good luck finding a block - you'll probably spend at least $100,000 in electricity before you find one.alim wrote:@A9sLWp9VHhbF Congratulations!!! my bank balance thanks you!
Should our earnings be higher from that?
Congratulations!
