Prohashing is recognising my T9+ as a scrypt miner im pretty sure its not
I tried setting c=Bitcoin, says its wrong algorithm. Any ideas anyone? Thanks in advance
Antminer T9+
Re: Antminer T9+
You need to add a=sha-256 to the password field line so it knows what algo to work with.
Re: Antminer T9+
Many many Thanks CSZiggy - All hashing away
Re: Antminer T9+
Personally, I would like to see the pool expand a bit and add ports for each algo.
prohashing.com:3333 scrypt
prohashing.com:3334 X-11
prohashing.com:3335 equihash
prohashing.com:3336 sha-256
Instead of the users adding the algo to the password field that needs parsed off, just add that variable based on which port they came in on.
I think something like that would take care of a LOT of initial issues newer people have coming in getting the password algo to match their miners.
But this late in the game, are you going to ask 21,000 workers to swap to a new port number, and what about ports being blocked other than 3333.
So there are pros and cons. When it was just scrypt the 1 port and 1 proxy worked fine, I just wish as they added other algos they would have gone with increasing ports to connect in on instead of the algo being part of the password that has to match.
Re: Antminer T9+
i think the bigger problem is that people don't take a couple minutes to read when all the information is there
