Need help with SHA-256 mining
In a few minutes, I'm going to enable SHA-256 mining. Since we had to return the S7 that we rented for testing, we need to make sure there were no regressions in the past few days caused by other things we were fixing.
If some customers would be interested in connecting to the pool, using a=sha-256, that would be great. That way, we can get a confirmation that a block can be found in the production environment. We don't plan to make a big deal in marketing about SHA-256 mining until after the new connection is installed, since we risk ourselves losing money due to orphaned blocks, but a small amount of hashrate now will allow us to iron out any issues before going big. Miners' earnings are not affected by our current connection because we are a pay-per-share pool.
Re: Need help with SHA-256 mining
I ll point one of my S9s there Steve, good luck to us both
tom
tom
Hmm tried to connect S9, it stops showing pools when I make prohashing the primary, I am not sure if it is working or not. Hard reboot of the device brought all info back up when i had it sent back to slushpool. Out of time, will check back later today or tomorrow.
tom
tom
S9 say that the pool is Dead, it go to backup pool
What is the error message returned when authorization is attempted?rulovico wrote:S9 say that the pool is Dead, it go to backup pool
NiceJobPoopin
a=SHA-256 (uppercase) as password shows pool is dead, a=sha-256 (lower) pool is alive. Accepted=2 after about 30 seconds...
Uppercase a=SHA-256 is working for me, says I found 6 blocks so far, but lost the leacoins
vaultminer
I just put 3 S9's on it. I used the lowercase password. I didn't try the uppercase password. I will put 10 more S9's on shortly
Thanks for that tip about the password casing. That shouldn't be that way. I'll add a fix for this problem in the next release.
Hi, Im trying to connect an S9, using a=sha-256 as the password, and pool is showing as dead. I would be happy to locate the error code if you could tell me where to locate it.
