Noob questions on GTX1060
Hello,
So I am new to this and I did want to try Prohashing, but I am afraid I am just not doing it right.
When I create a new coin on the Prohashing page and give it the address, after a short while it disappears.
That aside, I used OCM (originally for vertcoin) and pointed the minder to prohash.com:3333 and connected ok, with GPU at around 21 Mh/s.
But when I am mining vertcoin, at least I get responses and a "yes!" or a "booo". But when I try with prohash, I guess my GPU is too slow to even get a registration on. Does that sound right?
I'm only in this as a hobby to start with, so I am not laying out for some more serious gear, and I thought the idea of Prohashing was that you didn't need the serious gear? I'll start there and see where I can go
In the meanwhile I'll stick with the vertcoin that I know is working.
Re: Noob questions on GTX1060
equihash mining on GPU's is far more profitable than scrypt or x11 so....
i would use ewbf miner and password arguments "n=rigname a=equihash d=16384" you can leave out the d=16384 but with 1 1060 i would specify the difficulty.
so your start.bat file needs
miner.exe --server prohashing.com --port 3333 --user YOUR_USERNAME --pass "n=rigname a=equihash d=16384"
dont forget to choose the coin and % you want to get paid in on settings page
I gave this a try, but nothing was happening. I either got 0 Sol/s or when I got a positive rate, no connection occurred. I followed your instructions. But I can't actually run the program from the .exe file, when I run the bat file it works though.
hmm, i take it you did replace the YOUR_USERNAME with your prohashing username you use to log in, also make sure only 1 space between each command, i personally point my GPU rigs at miningrigrentals.com and set up the pool from there as i use smos a linux os (based on ubuntu), as it dosn't pass more than 1 password argument.slim6y wrote:I gave this a try, but nothing was happening. I either got 0 Sol/s or when I got a positive rate, no connection occurred. I followed your instructions. But I can't actually run the program from the .exe file, when I run the bat file it works though.
if your running windows which i assume you are i can teamviewer on to your machine and have a look for you, just send me a PM and we can arrange something.
You dont start mining by executing the .exe file.
Download ewbf miner from https://drive.google.com/open?id=0B9EPp ... Uh0YWFhOVE version Version 0.3.4b.
Edit the bat file :
Replace YOUR_USERNAME with your prohashing.com username. rigname can be anything.
Then to start mining double click the bat file.
Edit the bat file :
Great, thanks. I actually have the ewbf miner, so this is good. And my username, it is not email, right? Do I want d set at 16384? I will read their file and set it up as you have suggested. Does the balance instantly go to somewhere in my ProHashing account then I assume?
Ok, so I tried, I have done everything as suggested. I will provide screenshots:
This is the read out I get with EWBF miner: https://drive.google.com/open?id=1XJicS ... QnFRouZ2LB
Here is the .bat file: https://drive.google.com/open?id=1yXF2t ... 44G0dDTlCe
And here is the .cfg file: https://drive.google.com/open?id=1Qq18n ... 1eoWa9cJhk
All I get is the red "received incorrect work" and 0 SOl/s.
looking at your start.bat you need quotes around the password argumentsslim6y wrote:Ok, so I tried, I have done everything as suggested. I will provide screenshots:
Thanks. Will try that now.djliss wrote:looking at your start.bat you need quotes around the password argumentsslim6y wrote:Ok, so I tried, I have done everything as suggested. I will provide screenshots:
Yes, seems to be working now. I think I am getting somewhere. Will keep at it. Thank you.
